Black is pos. White is neg. If there was a battery installed you might have an inverter on board already. That would be nice. Someone with a Rockwell will help you out there. If you are lucky you will be able to set it up and have it charge while you drive (through your wiring harness to the TV.
You can run the furnace with one battery for a night or two as well as the lights. Not the fridge - that one or any other. A lot depends on battery size and condition. Look for a size 27 deep cycle with the highest amps you can get.
If you can find a reasonably priced solar charger that actually recharges enough for daily use you are a fortunate owner. I'd love to get one but the one's with enough juice seem to be huge and expensive. I'll be following this thread to see if you come up with something.
We can go a week in one place with two batteries using them for lights(sparingly) and water pump as well as charging small electronics.
Destinations on purpose: Canada: Alberta, BC, Nove Scotia, PEI, New Brunswick. USA: ME,NH,MA,VT,NY,MT,WY,MN,MI,WI,GA,VA,FL,UT,CA,OR,ID,CO,NV,AZ
:BLife is Good
2009 Jayco 1206
2011 Toyota Tundra
