Jul-12-2015 07:35 PM
Jul-20-2015 07:50 PM
Jul-20-2015 05:34 PM
Jul-15-2015 02:36 PM
mbutts wrote:
Another leak possibly is the top of the bunk door. On my 2007, the door warped from being clamped at the corners when closed and the corners were where the cables attached when open, so the bunkend corners were always under tension.
I closed up the camper on a sunny day and checked around the bunkend from the inside of the trailer. Very easy to spot where light was coming in.
Jul-15-2015 12:50 PM
Jul-15-2015 09:03 AM
JimNH wrote:
I might be tempted to cut the Filon or skin material back to the door area. The join can be a small vertical seam above and below the door opening, and that would help hide the transition, where you might need to have an overlap or use a piece of molding. the woodworking part of it is straightforward for someone with general carpentry skills - but the big "if" is how much bad material will you have to remove so that you are attaching everything to sound sub-structure. Removing what is left of the plywood skin should show you what you are up against. (If the damage goes further back in, I'd be tempted also to completely remove the front piece, and have a good look at the other corner as well.)
Good luck with this and please post pics and updates of your progress!
JIM in NH
Jul-15-2015 08:50 AM
Jul-14-2015 01:41 PM
Jul-13-2015 09:54 AM
n7bsn wrote:
There is a major RV builder at Red Bay Alabama, so there is certainly "parts" around there.
Jul-13-2015 09:53 AM
llowllms wrote:
Sounds like you may have had a roof leak to cause this problem. I just hope the previous owner was unaware of the problem before selling you the rv. What state do you live in? You may try to google rv repair shops to see if any are in your area. It would be fixable, the big question would be if it is cost effective or not. Good luck with this one. my regrets to the family.
Jul-13-2015 09:30 AM
Jul-13-2015 09:27 AM
Jul-13-2015 07:31 AM
My4men wrote:n7bsn wrote:
Actually from your photo, it's probably Filon and not Fiberglass.
Do you have a local RV parts place? They probably can get the RV stuff (Filon) you can't get other places
The lumber and insulation just comes from a home repair store
I live about 45 miles from Birmingham, AL so surely there's one in that area that will get the filon for me. Thanks for the clarification!
Jul-13-2015 07:25 AM
Jul-13-2015 07:24 AM
SteveAE wrote:
Bummer.
I concur with N7BSN, it can be done given enough time and effort. Done yourself, it shouldn't cost very much (perhaps under $600....but this is just a guess) and will look "reasonable enough" (not new though).
For the fiberglass, you may want to consider using filon. It comes in a variety of colors in large sheets and you just cut it to shape and glue on (with contact cement). Of course, this is after you have cut out all the rotted material and replaced it with solid wood. Then cover the seams between the old and new filon with trim pieces you either buy (where???) or have made. Or you could just cover the seams with strips of fiberglass tape and resin (of the same color) and sand to feather out (just like you would do a drywall patch).
The vinyl decals are the easy part as they can be custom made at a sign shop.
My biggest concern would be how much of the existing material you have to cut out to get rid of the rotted material? So you may want to do some poking around to determine this before getting too committed to the project.
Best wishes and do let us know how it turn out should you choose to go this route.
