buck2
Mar 31, 2013Explorer
Hot skin issue please help
Hi, I have a 1996 30 ft camper I'm having a hot skin issue where 50 v is leaking from shell of camper to ground. Each of the six breakers I have on my camper reduce this voltage as I shut each of them off( each drops hot skin voltage about 8-10 volts) and eventually when I have all the breakers off besides the main the breaker the voltage drops to 1volt. I also get increasingly more voltage up to the 50 volt hot skin issue when touching my volt meter between separate neutral bar and separate ground bar in electric panel ( each breaker I turn on increases voltage between ground bar a neutral bar 8-10 volts. How do I isolate what is causing this problem if all breakers are leaking voltage. Thanks
