rbpru's avatar
rbpru
May 28, 2015
How accurate are the truck scales.
I took my F-150 to the local Pilot CAT truck scales, centered it between front and rear axle scales and was surprised to learn front was 3480 lbs. the rear was 2820 lbs. The bed had 100 lbs. of potting soil in it and a fiberglass topper.
So the question is, does the location on the scales effect the weight? I was an equal distance on each scale. Also, what is the plus/minus poundage tolerance on the weight.
