- 2oldmanExplorer II4 two-bolt brackets per panel. Nope, just two directions.
- jdc1Explorer IIWho wants to climb up there to move it every hour? You'll end up wrecking your roof eventually (retired general contractor). You'll get 6 hours+ of great sunlight even in winter if they are mounted as they should be.
- CA_TravelerExplorer IIII read that 7 times on the roof is the average for panel adjustment. Most just add one additional panel and they are good to go.
- Yosemite_Sam1ExplorerThat's the reason why I did not mount mine on the roof.
Besides, I want my campsite under trees and tucked in the forest -- I can move my panel and need not the RV. - Ed_GeeExplorer IIMy panels are mounted flat on roof .... mounting brackets fastened to roof with 3M double sided tape. Mount brackets have option to add tilt bar for the panels if I am parked for extended period.
- LwiddisExplorer IIFour 2 bolt brackets for each of my three panels. Not interested in tilting...up and down a ladder repeatedly. Three panels sufficient so far. Will add a fourth someday. I wired for four panels. Hint - wire more than sufficiently.
- pianotunaNomad IIIMine are riveted to aluminum angle. The angle is held to the roof by six screws per panel.
- IvylogExplorer IIII took advantage of the raised side rails on my DP to tilt 7 of the 9 I installed.
- 12thgenusaExplorerMine are able to tilt in four directions. No running up and down. I just set them at the "optimum" angle for the latitude and month. I generally don't tilt if I'm going to be some place less than three days. It's more advantageous to tilt the further north you are. Some of us don't have the space to just add one more panel.
- beemerphile1ExplorerZ brackets and screwed to the roof
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 20, 2025
