blt2ski wrote:
Issue is NOT the motor! it is the cooling system of the tow rig. See if you can fix that frankly! I used to pull my 24' 6500 lb TT at 15K total with a 185HP motor too! granted it had 385 lbs of torque!
Marty
I put a 8'X11" additional cooler in the Trailblazer as soon as I purchased it. Covered most of one side of the rad. Still not enough. To put any more. I'd have to go with a thicker size one. And that would cost $200-$300, even if it would fit. And the latest thing is that the back window wiper doesn't work. So in addition to that this is the list of things that have gone wrong with it in three years: ignition switch had to be replaced, (just conked out at a road junction), right wheel bearing had to be replaced, tensioning pulley on the serpentine fan belt had to be replaced, remote key would not work in conjunction with couldn't lock back lift-gate, fuel gauge had to be replaced. You know what ? I'm fed up with trying to manage with its deficiencies!! Not sure I'll ever buy another Chevy product. Sorry, my rant for the day.
