- BurbManExplorer IIFYI, I spent $$ on the Darco OEM underbelly tape, but the best tape that I have found for underbelly use is the Gorilla Tape they sell at the home centers. Stuff sticks like iron and is impervious to the elements.
- K_and_IExplorerI recently had to do some work that required cutting the coroplast. The dealer had done some taping before I took posession of the camper, and this is what he used:
Tape
It had held up well for 10 years, so I bought the same and used it. I cleaned the coroplast with rubbing alcohol and used a little heat from a heat gun. It sealed up well. - GrandpaKipExplorer IIScrim tape for exterior application. Better than gorilla tape in my experience.
- LwiddisExplorer IIPost a review to the tech’s Facebook page. Shoddy workmanship!
- Grit_dogNavigatorThat makes sense, thank you.
I still believe I’d use Gorilla tape unless there’s an even better reccomendTion come up. - pmlevineExplorerThanks everyone. I have to redo the underbelly tape job done by an RV service tech - I had the black water shut-off valve/&cable replaced, the original underbelly of the TT had to be cut into in order to gain access to replace the valve/cable assembly. After returning home, I inspected the underbelly repair, and found several areas where the tech applied patch tape which did not cover some of the cut seams. I also did not find the patch tape to be of good quality - it’s a long drive for me to haul the TT back to the RV service site, so I’m redoing the patch tape job myself.
Phil - Grit_dogNavigatorSo seams on plastic.
Most degreasers, like used with water say for engines or floors etc leave a film.
Even some solvents like acetone still leave a film (not detrimental to tape sticking, but not acceptable for a paint prep.
If you use degreasing type cleaners I’d still hit it with a solvent or glass cleaner.
And yes good quality duct tape will last a long time. Especially when not exposed to UV. But Gorilla Tape is the bomb. - Microlite_MikeExplorer IIBest i've found is lacquer thinner or acetone. Other "degreaser" type cleaners work too.
If the underbelly area you are applying new tape has dirt/mud on it, clean first with some spray cleaner like 409, etc. Then wipe with lacquer thinner or acetone. (not mineral spirits/paint thinner as it can leave an oily residue behind).
The more free the surface is free of oily residue, the better the tape's adhesive will stick.
As for Tape, I really like Gorilla Tape in Black for taping my trailer's belly cover where needed. I might even consider Eternabond if I needed something more durable and Eternabond recommends cleaning with their cleaner which is just Acetone in an aerosol can. They also have a primer that really makes their product stick. - Grit_dogNavigatorNot sure what the tape is doing, what kind of tape it is, or what it is being applied to, but the following applies regardless.
Clean dirt off first.
Then a solvent to remove any oils or contamination if the surface is solvent resistant.
If not, good ole glass cleaner like like Sprayway work well also
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
