RvingKC
Aug 07, 2013Explorer
How to empty tanks on a Palomino Solair 267BHSK
First I'll admit, I am a newbie. I'm hoping someone with an RV similar to ours can help answer a question. We just bought our first TT, a 2014 Palomino Solair 267bhsk. It has two grey tank valves and the normal one black tank valve. Everything I've read and watched says to never open the black and grey tanks at the same time...that you open then close the black, then open and close they grey. However (and we've not used the black yet so it's still clean from the mfg) we've found that the only way the RV will drain the grey tanks is while the black is open too. Are we confused on how the tanks flush or is our RV different or do I need to talk to the dealer?
I looked in the user manual and the Palomino website and it says the same thing:
'Remove the termination cap outlet, connect the sewer hose (adaptor) to the termination end, place the other end into an approved dump station inlet, open the black (sewer) water termination valve first, once dumping slows down, open the gray water termination valve, once contents are dumped, close termination valves, flush sewer tank with water, open termination valves one at a time until empty, close termination valves, disconnect sewer hose and store, install termination cap, add approved chemical deodorant as per manufacturer’s instructions.'
