Jan-26-2019 09:22 AM
Jan-28-2019 08:33 AM
Jan-28-2019 08:03 AM
Grit dog wrote:BubbaChris wrote:
One thing I haven't seen mentioned in this thread, if both trucks are 3/4 ton you'll lose a fair bit of payload in the CTD version because of the heavier engine (and supporting parts). Compare payload stickers between 2500 and 3500 versions of the CTD if you go the diesel route.
Best regards,
Chris
Only on paper or in your mind. Real world, payload capabilities are very close.
Please don't confuse beer brewer. He's already in a conundrum of epic proportions about the truck he might buy. I think we've been through most of the scenarios already.
Jan-28-2019 07:46 AM
Bionic Man wrote:
Yeah. Because having to replace an engine at 371,500 miles when it is used almost exclusively for towing is pretty embarrassing.....
Vern, you should know by know that all those 3.0 diesels are worthless. Your low mileage before overhaul proves that......:R
Jan-28-2019 07:23 AM
Jan-28-2019 07:21 AM
mkirsch wrote:ScottG wrote:
And when your done with it you get the extra cost of the diesel back.
Many people will try to convince you of this, but it is not true.
You will get a PROPORTIONAL amount of the cost back at sale/trade time. That will be the same proportion as the used vs. new value of the rest of the vehicle.
They like to tell you that if you spend $10,000 extra on the diesel, your truck is worth $10,000 more at sale time. Nuh-uh. If the rest of the vehicle is only worth 20% of its original value, you only get 20% of your diesel money back.
Jan-28-2019 07:13 AM
Jan-28-2019 07:11 AM
Jan-28-2019 07:06 AM
VernDiesel wrote:
Yes at 371,500 she pushed out a head gasket likely in part due to having been low on coolant. (more than once as I had been dealing with a coolant leak) This has been covered on this forum several times is not hidden and was not part of the 8 speed transmission discussion. Apparently I should add a signature line with this info in it. 🙂
Jan-28-2019 06:32 AM
Jan-28-2019 05:48 AM
ShinerBock wrote:RoyJ wrote:VernDiesel wrote:
Get the coming 6.4 Hemi with 8 speed and 4.10. Consider the factory rear air ride as well. I have 500,000 miles (transporting TTs commercially) on a 14 Ecodiesel 3.92 and have towed 8k TTs many times. The transmission has never been repaired and still shifts quick and firm. But I have changed the fluid 5 times now. I would say consider the ED as you will use A LOT less fuel but IMO 8k is about the max practical load for a half ton platform to tow a TT.
Holy ****!
Totally changed my view and doubts about an ED!
He is on his second engine.
Jan-28-2019 05:27 AM
Holy ****!
Jan-28-2019 05:25 AM
Jan-28-2019 04:59 AM
Jan-28-2019 02:17 AM
Jan-27-2019 09:40 PM
