- campingwiththorExplorer9/30 Thank you for the reply. Will investigate the hex nut and or motor break options if the slide motors are trashed from the high waters. Will know in the next couple weeks.
Thank you ????CA Traveler wrote:
On many/most electric motor slides there is a hex nut that you can wrench on to turn the motor. Another option is to release a motor brake and wrench on the cross bar.
But hopefully they will be OK when you get there. - CA_TravelerExplorer IIIOn many/most electric motor slides there is a hex nut that you can wrench on to turn the motor. Another option is to release a motor brake and wrench on the cross bar.
About Travel Trailer Group
44,027 PostsLatest Activity: Mar 05, 2025
