โMay-19-2018 02:29 PM
โMay-21-2018 10:05 PM
โMay-21-2018 10:02 PM
FishOnOne wrote:Cummins12V98 wrote:
"Reduce air pressure improves ride a bit but increases wear rate"
FISH this time you are way out in left field with that comment!!! Using weight/inflation chart to set PROPER air pressure will NOT increase tire wear!
On my 2500 4x4 RAM I could easily get 100K out of BFG's and 120K from Michelin's by reducing air pressures based on load.
Anyone who pulls some weight would be hard pressed to get 100k-120k miles on a set of tires.
Probably a figment of your imagination.
โMay-21-2018 08:08 PM
โMay-21-2018 08:05 PM
Me Again wrote:FishOnOne wrote:Me Again wrote:FishOnOne wrote:
I think Rancho's quality is not the same as it was when your purchased your set.
https://www.amazon.com/Rancho-RS9000XL-Shock-2005-2016-Super/dp/B01LRJ6ZUG/ref=sr_1_3?s=automotive&i...
All of those reviews are most likely new installs. I agree with most of them when new, but disagree after 15k miles of use.
Well I will give you a report over the next few years as a set are going to go on our 2015 this summer. We are not going to tow the 5th wheel back to Arizona this winter, so what to be able to soften the ride for the bobtail run South.
BTW
LIMITED LIFETIME WARRANTY (limited to qualifying Ranchoยฎ products only)*
Tenneco warrants qualifying Ranchoยฎ products against defects in materials or workmanship (except finish) when used under normal operating conditions for as long as the products are installed on, and the original purchaser owns, the original vehicle on which they were installed.
LIMITED LIFETIME WARRANTY QUALIFYING PRODUCTS:
Ranchoยฎ quickLIFTโข
Ranchoยฎ RS9000XLโข Shock Absorbers
Ranchoยฎ RS7000MTโข Monotube Shock Absorbers
Ranchoยฎ RS5000โข Shock Absorbers
Ranchoยฎ RS5000Xโข Shock Absorbers
Ranchoยฎ Light Truck Suspension Components
Chris
โMay-21-2018 04:56 AM
โMay-21-2018 04:50 AM
BTW
Chris
โMay-20-2018 05:14 PM
โMay-20-2018 04:28 PM
Grit dog wrote:donn0128 wrote:
Might want to swap it for a much newer 2500 with coil rear suspension. That will give you the soft ride.
You buying it for him or what?
โMay-20-2018 03:30 PM
โMay-20-2018 03:19 PM
โMay-20-2018 12:08 PM
Questionable:
Rancho 9000's are absolute junk
Had them on our 2001.5 for over 10 years and they were still preforming the same as the day I put them on when I sold the truck. What is your experience with them that leads you to state they are junk? Chris
โMay-20-2018 10:26 AM
Questionable:
โMay-20-2018 10:21 AM
FishOnOne wrote:
Questionable:
โMay-20-2018 10:07 AM
โMay-20-2018 10:03 AM
