jefffoxsr's avatar
jefffoxsr
Idle problem 2003 GMC Yukon
The idle hunts up and down for a few minutes after starting the truck. My scan tool never shows any malfunction codes. What could be causing this and what can I check to be sure? Thanks.
  • enblethen wrote:
    Some GM engines hae an "Idle Air Control" (IAC).
    It is located on the lower portion of the throttle body assembly.
    It sort of acts like a choke.
    Not sure if your rig has one.
    That would be my WAG as well.
  • Some GM engines hae an "Idle Air Control" (IAC).
