LoneStar1
Mar 07, 2015Explorer
If only Ford would build this...
Turbo 6.2L Ford Super Duty (Ecoboost 6.2L)
http://www.ford-trucks.com/forums/1345900-twin-turbo-build-3.html
285 RWHP Stock 305 pound-ft of torque*
545 RWHP 7psi boost 575 max torque*
675 RWHP 10psi boost torque more than 700(off the chart)*
*Please note that car manufactures generally measure HP and Torque on an engine dyno and these are the numbers that they publish. A chassis dyno gives a more real measure of a vehicles performance because the readings are taken from the drive wheels. These readings will be about 20% less than those taken from an engine dyno because of the drag placed on the engine by the transmission, differential, and accessories. The above readings were taken on a chassis dyno.
Compare with a stock 2009 6.7L Dodge diesel that puts down approximately 270 HP and 532 pound-feet of torque at the rear wheels on a chassis dyno.
http://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-6-7l-only-170/6-7l-dyno-numbers-243069/
