Boatycall
Feb 11, 2018Explorer
In-wall space heater install on Eagle Cap 1160
So yesterday I went to work on my solar and got that up and running. Today's weather was not to be as good, so I wanted to knock out a much easier project, installing an in-wall 110v space heater. I had been using just a plug in freestanding heater when I'm heating it for winter or camping in a place with hookups. I wanted to ditch that and build one in.
The only place in the whole TC I could find that had a place to mount, unobstructed venting, and accessible wiring was into the dinette seat cabinet, facing it upwards towards the bunk -- which is perfect because the furnace doesn't do a good job getting heat up into the bunk area.
First - power. Redo the fridge's outlet. It's on a 15a circuit, and is the only thing on that circuit except an outlet inside.
![](http://www.osorc.com/files/misc/heater/heater1.jpg)
![](http://www.osorc.com/files/misc/heater/heater2.jpg)
I made a heavy duty plug in to plug into it (the one in the pic is the fridge). EC had already tapped a second outlet on it, so I opted to just use a plug in.
Drilling a hole in the wall and running the wire was a bit of a pain - had to break out a wire fish, I kept hitting (presumably) a wall brace. Finally got a wire route through and down.
![](http://www.osorc.com/files/misc/heater/heater3.jpg)
Next, cut a whole in the dinette pedistal
![](http://www.osorc.com/files/misc/heater/heater4.jpg)
Wire the thermostat--
![](http://www.osorc.com/files/misc/heater/heater5.jpg)
I also took this opportunity to run an outlet next to the storage door since there isn't an outlet on that side of an EC.
![](http://www.osorc.com/files/misc/heater/heater6.jpg)
Heater mounted and wire run
![](http://www.osorc.com/files/misc/heater/heater7.jpg)
Final mounting of the heater and thermostat
![](http://www.osorc.com/files/misc/heater/heater8.jpg)
![](http://www.osorc.com/files/misc/heater/heater9.jpg)
I went with a Broan 750/1500 watt because the heat element can be split to either 750 or 1500w. The thought there - I'm plugged into just a 15a extension cord I can still run the heater and fridge. I'm plugged into 30a service I can switch it to 1500w. It's intended to be hard-wired one way or the other permanently, but very easy to modify with a switch to the second heating coil.
It's also upside down - I wanted the vent pointing up into the bunk rather than down into the floor.
