Acdii's avatar
Acdii
Indoor storage question
I plan to move my trailer into my barn this weekend, it is already winterized, have 2 1/2 gallons of the extra special pink stuff in the system, heat tank cleaned out and drained, and will get all the good packed up and put away, dryer sheets, etc. But what I would like to do is remove the wheels while stored and place the trailer on stands. What weight stands should I use for this? The trailer is about 6300# wet, probably removing 150# of good from inside, not completely emptying it, just stuff that can freeze, Bedding and towels will go into a locking container, and I already stuffed openings with steel wool. Around the jack stands I plan to pour mothballs, rodents HATE mothballs. If I can not put the stabs down during storage that would be good as the rears will be in dirt, while everything else will be on concrete.
To get it in the barn I have to remove the 14" wheels and use 12" so that I can clear the door and trusses. Trailer height is 10'8" door height and trusses 10'8". The AC unit is a tall SOB. Once I get it in, I want to put the stands under the axles and leave it that way until spring.
