inverter question
daily_double
So I'm going to remove my battery for the winter, but what do I do about the Inverter ? Do I just tape the wires up and forget it, or do I have to disconnect the inverter to keep from sending power to where the battery used to be?
15 REPLIES 15
3_tons
True enough! My comment was in the context of a portable generator (what I have, though not sure what OP has)โ€ฆ
3 tons
jimh406
3 tons wrote:
Well looking forward, taping the leads might be a good idea in the event you at some point inadvertently start the generator without having the battery connected (regardless if you mean converter or inverter).
Most builtin generators are started with house batteries, so probably will have batteries installed to start them.
3_tons
daily double wrote:
No the unit has been winterized and shore power disconnected
3 tons
daily_double
3_tons
So, are we to โ€˜assumeโ€™ that the RV will be stored with shore power connected??
3 tons
Grit_dog
Nomad III
Nomad III
And I think youโ€™re confusing inverter from converter or ????
Converter = charger/DC power supply converter from AC source (plugged in)
Inverter pulls power from DC source, battery or converter if plugged in and turns it to AC power.
If youโ€™re implying youโ€™re leaving the camper plugged in and wanting to pull the LFP battery due to cold, that is a bad move. You want/need a battery in the circuit If youโ€™re leaving the camper hooked up for whatever reason.
Grit_dog
Nomad III
Nomad III
If itโ€™s a LFP, just disconnect it if you have any parasitic discharge and donโ€™t worry about visiting it until spring. No need to float or trickle charge and sitting in cold temps wonโ€™t harm it.
Done deal.
You can remove it as well. But donโ€™t try to float it or keep it โ€œtopped off.โ€
pianotuna
Nomad II
Nomad II
MitchF150 wrote:
Kinda confused on your question, but that's not unusual for me.. ๐Ÿ™‚
If you are plugged in and it's sending some charge to the battery (any style of battery), won't that keep it 'warm' or at least a steady 13+v, even on "float"?
If you not plugged in, then just remove the battery and there should be no power to the rig at all, correct?
Anyway, good luck with whatever you end up doing! ๐Ÿ™‚
Mitch
doing that to an Li may turn it into an expensive door stop.
Regards, Don
2oldman
You sure you don't mean converter?
MitchF150
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
daily_double
I am removing because it's lithium and I don't have any way of heating it.
KD4UPL
If it's just an inverter then just let the wires hang. If it's an inverter / charger you need ti disconnect it from AC power.
If you have access to AC power you may as well leave the battery and let it float charge.
time2roll
Depends. Is the RV plugged in? What is the make and model of the inverter?
pianotuna
Nomad II
Nomad II
Leave the inverter alone.
Why are you removing the battery?
Regards, Don
