OttawaDon
Sep 29, 2015Explorer
Is such a low cargo carrying capacity possible?
Hi folks. We have found a trailer floorplan that we very much like in the Evergreen i-Go 245 RKDS. I found a 2015 model at a dealer about 2 hours away and they seem very motivated to give me a good price as the 2016s are coming in.
I haven't yet seen the trailer in person to check the listed spec sticker, but the Evergreen site lists this model as having a cargo carrying capacity of only 488 pounds. This seems like a mistake to me but I wanted to check with you folks to see if this is indeed possible. If true, what could cause it to have such a low ccc. The specs are listed below, with such a difference in the dry weight vs the GCWR, does this seem right?
Total Dry Weight* (UVW): 5,052
Dry Hitch Weight* (LBS): 656
GVWR* (LBS) 6,495
Fresh Water Capacity (GAL): 36
Gray Water Tank Capacity (GAL): 58
Black Water Tank Capacity (GAL): 29
LP Capacity (LBS): 40
Cargo Carrying Capacity* (LBS) 488
Overall Length: 27' 3"
Height (including A/C): 11' 1"
Width: 8' 1"
Bed Size: 60x80
Awning Length: 18'
Tire Size: ST205/75R14-C
GVWR* (LBS) 6,495
Width: 8' 1"
Bed Size: 60x80
Awning Length: 18'
