Kach
Aug 04, 2020Explorer
Is this a problem?
We have a 2021 Highland Ridge - Open Range stick and tin (conventional) trailer. It has a 3/8” walkable roof deck, although ours did not come with a ladder. I noticed the other day from my stepladder that the roof surface is not smooth. Most noticeably, the seams look terrible although all is intact and well sealed. Whatever is over the seams (under the roofing membrane) is relatively soft and smooth so that part just seems cosmetic.
The other weird thing I noticed is that the roofing surface seems to have an embossed look with the OSB type material surface showing through. I can feel the material texture under it as welll.
This is a PVC roof which is supposed to require less maintenance than conventional or TPO roofing, but other than that I don’t know much about it...
