Wharfcat
Jan 21, 2019Explorer
Jack shims
Since I've had to put 4" of pink foam in the pickup bed to accommodate the higher cab on my Ford, I'm nearing the maximum travel on my jacks. An inch or two would really help. What to you use, if anything?
NRALIFR wrote:
How do you feel about making your extender plates over again, except about 4” longer? Then move the jacks down on them.
Kayteg1 wrote:
Carefull, carefull.
What is your camper weight?
I've been using campers with 4000 + lb dry weight and when I bought them, both of them had extender plates bent. I estimate when I am lifting my loaded camper, front jacks carry over 2000 lb EACH and it doesn't take much for the thing to star going.
Extensions will only magnify the problem, so I would rather carry some wide wood planks, what will also give you option for easy shimming on uneven pad.
Kayteg1 wrote:
Carefull, carefull.
Homeless by Choice wrote:
I tried doing that also BUT the inside of the jack legs had to be on the very edge of the blocks so that the blocks cleared the tires. It was VERY easy to slightly bump the block while moving the truck and having the jack slide off the block. That is when I bought the bolt on extensions. The bottom plate of the original leg and the top of the extension are oval shaped approximately 2.5" X 3.5" and rub on my tires as I move the truck back and forth but because they are bolted on (two 5/16 bolts), nothing moves, nothing falls.
LeRoy
Wharfcat wrote:Kayteg1 wrote:
Carefull, carefull.
Yes, that's what I was thinking too. 1" Plywood or 1"X 10" or 1" X 12". I have done that in the past not so much to give extra clearance but if I was unloading on firm dirt/grass to spread the weight. Sometimes low tech is best. Just thought I'd ask.
