JCR-1's avatar
JCR-1
Jacking single axle trailer
Everywhere I read that the proper way to jack up a single axle trailer is by using the chassis frame rail. They (manufacturers) and industry never recommend the axle for a jack point even if you use the spring perch. I just wonder why the end of the axle is not the best or even suitable by their recommendations. I believe these axles are cambered and to lift even by the perch may stress the curvature to a negative or flatter arc and may reset the arc unfavorably. ??????
