โJun-14-2016 04:54 PM
โJun-16-2016 10:33 AM
wilber1 wrote:rhagfo wrote:wilber1 wrote:transamz9 wrote:
For all you people saying that reading the owners manual will tell you everything. Tell me the page number to where it tells you how to disable the seat belt chime on a Ram truck.
That seat belt warning is required by law, there is no way a manufacturer is going to publish how to disable it.
The manual doesn't tell you everything but is always a good place to start. There is lots of good information there and I go back to mine frequently even though I have had my truck for five years. The last time was just recently to find out how to change a DRL bulb.
Just wondering why you would want to disable the Seat belt warning light/chime???
I don't know. If I am just moving a short distance not on public roads and I am going to be getting in and out, I just buckle the belt behind me. Much easier than going through some drawn out procedure to disable the thing.
โJun-16-2016 09:55 AM
โJun-16-2016 09:44 AM
Wanna bet?
โJun-16-2016 08:47 AM
โJun-16-2016 08:27 AM
โJun-16-2016 08:26 AM
transamz9 wrote:4x4ord wrote:
You're the first guy on this forum who bought a new Ram to admit that you're a bit confused??.....sorry I just couldn't help it. I only turn the exhaust brake on while towing. I seldom use tow haul. Often on steep grades I manually select the gear I want. I sometimes lock out 6th gear while towing at speeds below 65 mph. I'm not certain but I think my fuel economy may at times improve running in 5th vs 6th. (This will depend on gear ratios, travel speed and weight of the load.
The Ram exhaust brake set up is not as it is on the GM and Fords. It does take a little user input to get full potential out of it. Ram should do a little better job of teaching the buyers how to use it but that would mean that they would have to train the salesmen. Well, you know that ain't going to happen. LOL The EB in the RAM does a good job on it's own just like the GM and Ford but once you learn how to use it to it's fullest IMO the RAM is in a league of it's own. The only thing I wish they would do is give an optional heavy mode that would allow it to engage more when towing heavy but that would be a safety concern for people that are not experienced in using an engine brake on wet or slick services.
โJun-16-2016 08:23 AM
โJun-16-2016 08:15 AM
โJun-16-2016 08:12 AM
โJun-16-2016 08:11 AM
thecdnmole wrote:Cummins12V98 wrote:thecdnmole wrote:Cummins12V98 wrote:
TH and EB on ALL the time! Try the "Auto" mode solo. I run full on ALL the time. You will never wear out the brakes.
I have not towed with mine yet, but soon, very soon. I try to turn on the EB all the time, which does save on brakes, but on my 2015 Ram it stops working when it slows to 50 mph! Whereas in my 2011 Chevy it would stay on till about 30 mph. I am curious how it works towing.
Put the TH on ALL the time. Your EB should stay on down to around 1,100 rpm's.
So as stated by Arcamper previously, EB is determined by engine rpm, not speed? Good to know!
โJun-16-2016 07:06 AM
โJun-16-2016 07:03 AM
โJun-16-2016 07:01 AM
minnow wrote:
Those using T/H mode; are you using it even when not towing and on the open road ?
Also any reason why one would use the EB all the time as compared to using it in Auto mode.
โJun-16-2016 06:46 AM
โJun-16-2016 06:30 AM
