N-Trouble wrote:
ktmrfs wrote:
we had a 04.5LLY with 315 HP and now have a 2015 with the 397HP. We tow a 10,000lb trailer over the rockies. Do I notice the extra 75HP? slightly. does it make any difference in towing? not really. even the 04.5 was capable of holding the speed limit, or safe speed on any climbs I did with power to spare.
Personally, I wouldn't do anything
How does the mileage compare towing the same load? Bet the 2015 feels a lot more capable towing with the improved frame, brakes, suspension and exhaust brake over the older model.
towing mileage is virtually the same. still pushing a barn door through the air.
Unloaded highway is better by over 1mpg. with the 2015 I can average 20mpg on a 750 mile trip over the rockies between portland and central montana. the 04.5 was usually 18, maybe 18.5
towing wise, both are very comparable. Yes, the exhaust brake is the most noticeable difference. Otherwise the 2015 is much quieter, more refined features, but handling wise both are very very capable. And finally the short box comes with a 36 gallon fuel tank instead of the 24 gallon. Also has several inches more rear leg room,
and even though the 2015 has an 800lb higher GVWR, it actually only gained about 300lbs in payload, like us, the truck has put on some weight over the years!!
