wnjj
Mar 06, 2018Explorer II
Lantley wrote:rhagfo wrote:
I ALWAYS make it a habit of checking around slides before opening or closing to be sure they are not going to catch on something. Really simple concept! :S
Sounds simple but when you have a multi slide unit in a multi room RV the slides are not always visible to ensure nothing will be damaged
Then there are truck campers with slides that aren't as easy to climb up into and look before deploying plus some models require you to open a slide to even enter. If they came equipped with poorly-latching interference fit cabinets they would have to be dealt with properly. Making a latch that works is pretty simple too. When multiple users suffer the same fate and it's avoidable with a design change why shouldn't the design be changed?
