- goducks10Explorer
Roger10378 wrote:
I would think the insurance would deny any claim. This is pure and simple stupidity on the part of the owner.
Thats why they cancel you after they pay damages. It's their way of weeding out the dumb a$$'s. - JRscoobyExplorer II
lane hog wrote:
I'm also surprised the crankshaft gave up before the transfer case did. I always thought the chain in the case was made to be a first line of defense from bad things happening i.e. you over-torqued while under power. Curious if the fact the transfer case didn't go first is indeed a manufacturer defect.
When I had to pay the bills for what a driver tore up I hoped the driveshaft would go before a box of gears.
I would think the transfer case would handle all the power the engine could put out. I thing the engine damage was speed, not power.
What surprised me is the tires where able to overcome friction to push all the gears without sliding. - lane_hogExplorer II
Learjet wrote:
Thank you...harsh crowd here..not like someone has never dropped a fifth wheel trailer, turned to sharp with their short bed truck and fifth wheel or put gas in a Diesel...etc
I've done two of the three... and neither one required a trip to the shop or an insurance claim, but I've heard about it from my wife for years and that's much worse.
Re: the Jeep.... two thoughts.
I'm surprised the driver couldn't feel the resistance from being in gear. We dolly-towed for 13 years and I never once didn't feel the weight of the van behind us. Having the car in gear would have felt a lot different.
I'm also surprised the crankshaft gave up before the transfer case did. I always thought the chain in the case was made to be a first line of defense from bad things happening i.e. you over-torqued while under power. Curious if the fact the transfer case didn't go first is indeed a manufacturer defect. - LowRyterExplorerI don't know about the Jeep but I'm pretty impressed with the tow vehicle.
- dodge_guyExplorer IIYes the transmission output shaft will spin due to fluid dynamics. Similar to how a torque converter works. With it in gear the shaft won't spin. These transmission do not lubricate themselves like some other manual transmissions do when they are flat towed. So if the trans was allowed to free wheel it could potentially damage the internals. Although in this case, the trans was being lubricated until it surpassed its rpm rating. LOL
You see all sorts of stuff working at a dealer. Right now I have a Ram 3500 dually with 9500 miles that the owner destroyed the rear axle on. It's a hotshot tuck, They hit something 5k miles ago (that's 5k miles in 2 weeks time) and replaced the 2 right side dually tires with Firestones and left the factory Nexens on the other side. Well they got an ABS light, I removed the sensor in the rear axle and found metal attached to it. Pullled the cover and found metal everywhere. The spider gears destroyed themselves. The reason.......the Firestones are a 1/2" larger in diameter than the OE tires. Causing the spider gears to be in continuos rotation (they are only designed to be rotating when turning corners), not in continuous operation for 5k miles! So it need a complete axle assembly. Right fender is damaged and the liner is missing, but the owner insists they didn't hit anything! LOL - wnjjExplorer II
RoyJ wrote:
spoon059 wrote:
dodge guy wrote:
spoon059 wrote:
And they left it in gear. TWO major mistakes.
its actually supposed to be in gear with the T-case in N.
Didn't know that. Read up and see that the transmission must be in gear to keep things lubricated as it moves down the road. I retract my statement.
Unrelated, but why 1st or 2nd gear instead of 5th gear? Seems that 5th gear would keep rotation/lubrication, but with less rotation/stress than a lower gear.
I still don't get why the transmission needs to be in gear - if the t-case is in neutral, then the transmission is not spinning regardless of in-gear or neutral-gear.
Am I missing something?
If the transmission is in neutral there is nothing stopping the output shaft from starting to turn just due to drag within the transfer case. - HuntindogExplorer
RoyJ wrote:
Yes,unless the drive shaft is removed, the output shaft in the tranny and whatever it is connected to is spinning as well.spoon059 wrote:
Actually there are differnt ways it can be designed, but if the manual says it needs to be in gear..... There is a reason. - RoyJExplorer
Am I missing something? - spoon059Explorer II
Unrelated, but why 1st or 2nd gear instead of 5th gear? Seems that 5th gear would keep rotation/lubrication, but with less rotation/stress than a lower gear. - JRscoobyExplorer II
Reisender wrote:
I like the idea but I would think it would require some kind of special towbar. I don’t think traditional tow bars are meant to push. There would have to be some pretty funky software written by the manufacturer of the EV as well. Thinking it might be awhile. :).
The software is way past me. I hate my hand-me-down smart phone because it is hard to make calls compared to my old flip phone.
Special towbar? The one used by everybody that doesn't think their toad needs brakes takes a lot of pushing.
AFAIK, no EV manufacturer has said their product is good for 4-down. But I can't see near as much trouble as IC vehicle. Normal brake and light solutions would transfer. If could tell it to regen when Jake comes on, so much better.
About Travel Trailer Group
44,056 PostsLatest Activity: Jan 12, 2020
