DTLJ's avatar
DTLJ
Kodiak 221rbsl leaking on floor in front of refrigerator
I have problem with a leak on the floor in front of my refrigerator on my 2012 Kodiak 221 rbsl travel trailer. Anybody else have this issue can't figure out where leak is coming from.
  • I've had two of these types of leaks. The first was caused by rain coming in through the outside vent. I used some duct tape to fill a gap at the bottom of the vent frame and that stopped the rain from coming in.
    Second one was caused by a loose water connection for the ice maker.
  • How cold and humid is it in your area? I had what I thought was a leak but it turned out to be condensation. Warm moist air inside, cold air outside and the water condensed out on the inside of the wheel wells (inside cupboards, behind the tub etc.).
    If you check inside a cupboard or under the fridge you may find this problem too. Maybe a drain line from the fridge has detached and is dribbling on the floor. requires a look from the outside I think.
    Does it leak with slide in or out?
    Is it a round puddle or elongated?
    Long story short couple months ago after towing home in 3 hours of heavy rain from camping I had small amount of water in a puddle on kitchen floor.
    I tracked it down coming from top of my slide while retracted.
    I had a very small pice of tree limb on top of slide that allowed tony gap in slide seal
    The other time I had puddle was when my outdoor kitchen sink water line loosened up at faucet and it traveled inside. My sink slides in and so it's prone to loosening up.
