NRALIFR
Sep 12, 2018Explorer
The LP fuel supply to your generator is fairly straightforward. The LP pressure is regulated by the regulator at the LP tanks, so you should rule out any problems with it before digging into the generator too much. It should be a minimum of 11” water column on a manometer. It will normally be adjusted a little higher than that so that when all your LP appliances are running, you still have 11”.
After the LP goes through the campers regulator, it then goes to the lock-off solenoid on the generator. That solenoid is controlled by the gen-set, but you should be able to easily determine if it’s energized and open or not with a test light. If the lock-off solenoid is opening, the LP then goes to a device that looks like another LP pressure regulator. It’s called a zero-governor regulator, and it’s purpose is to only let LP flow to the carburetor on the engine if there is vacuum in the intake manifold, like when the engine is either cranking or running. The size of the diaphragm in the zero-governor makes it very sensitive to vacuum, and it should open on its own when there is even the slightest vacuum in the intake.
The diaphragm in the zero-governor can get pin holes in them which makes them less sensitive to vacuum, and the little valve inside the governor can stick closed. Both issues can make the generator hard to start. If you end up replacing the zero-governor, try to find one that has a manual prime button on it so you can force it open when needed. It makes the generator easier to start if you can prime it before cranking, and it makes troubleshooting a problem like this easier.
I think it’s less likely the zero-governor was the cause of the first shutdown/unable to restart incident. That sounds more like the gen set overheated, had low oil pressure, or one of the sensors that detect those conditions is failing. I’ve had to replace one or both of those sensors on the built in Generac in my TC, and the standby generator on my house. If you can get to those sensors and unplug them the next time it won’t start, that may help isolate the problem. If the generator starts, the sensor is bad.
44,026 PostsLatest Activity: Mar 01, 2025
