scottkeen's avatar
scottkeen
Onboard Generator or 2 Portable Generators + Solar + Battery
I have a 2011 Montana 347THT fifth wheel toy hauler and it has the gen-prep package with the shielded generator bay and wiring to a generator on/off switch inside the RV.
I just bought it used less than a month ago, and am looking for what power options I want to get for it. It came with a dealer-provided 12V 58Ah lead acid battery which will yieled 29Ah if I run it down to just 50%
I bought the RV with the intention of doing more dry-camping, boondocking and less campground-parks. My hopes are to go full-time and be largely energy independent.
I expect to follow-the-weather and run one 15K BTU AC only if I'm stuck somewhere in unbearable heat.
I'm considering my generator/battery/solar options with costs the same. Here's how I see it:
Option A: Onboard Generator - Gasoline
$3100 Cummins/Onan 4000 gasoline onboard generator (4000W rated)
$ 400 (est) gasoline tank under trailer between frame rails
$3500
Option B: Onboard Generator - LP
$3500 Cummins/Onan 3600 propane onboard generator (3600W rated)
Option C: Portable Generator + Solar + Battery
$2050 (2) Honda EU2000i + EU2000ic with parallel kit (4000W peak, 3200W rated)
$ 640 Renogy 400W solar kit (PWM, upgrade to MPPT later)
$ 900 Renogy 12V 100Ah Lithium Iron Phosphate battery
$3590
I like the convenience and extra rated wattage of the gasoline onboard generator, and the convenience of the LP onboard generator and lower maintenance of LP vs gasoline.
But hard to argue with getting almost the same rated wattage from a couple of Honda portable generators and the option of only using one generator at 2000W (1600W rated) if that's all I need. Plus I would be getting a 400W solar kit and a much-desired 100Ah LiFEPO4 battery which I can run down empty, with more charge cycles and lighter weight than SLA.
I'm leaning highly to Option C, but the convenience and more power of Option A and B are really nice.
Your thoughts?
