Larger fresh water tank ?
daddyfarlessa
I own a 2014 Airstream International Serenity (23')
I posted this query on an 'Airstream Forum' website, but as of yet have received no reply.
My trailer has a 39 gallon fresh water tank & I'm inquiring about installing a larger tank.
fyi - all the Airstream holding tanks are inclosed in a sheet metal container (which are heated to prevent liquids from freezing in cold weather).
Any info/referral will help.
Thanx ~Mark
12 REPLIES 12
harold1946
BarneyS wrote:
harold1946 wrote:
Try presenting your question on the Airstream Forum, there may be some that have made such a modification.
http://www.airforums.com
2nd sentence in his opening post says:
"I posted this query on an 'Airstream Forum' website, but as of yet have received no reply."
Barney
There are many Airstream forums. I gave him the one that I felt is the best. The word "an" indicated to me he only posted on one.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
sky_free
Some numbers for your TT:
Dry weight: 4806 (no options)
GVWR: 6000
Weight with 39 gallons of water: 5131
So that leaves you 869 lbs for any options you've added, the weight of 2 full propane tanks, and all of your stuff. Have you ever weighed it fully loaded for a trip?
That's probably why a larger trailer like yours only carries 39 gallons of fresh.
That's a pretty heavy trailer so I assume you are towing it with a truck. Horse "people" often carry extra water in truck-bed mounted water tanks with pumps. You can carry a lot more water safely in the bed of your truck than you can adding it to a frame that's already loaded to near or over GVWR.
2017 Escape 17B, 2012 VW Touareg
pickjare
We also have found 4 aquatainers are the way to go. They are bpa free. Go to Home Depot and buy 1/2" clear vinyl hose. It almost fits up inside the spout in the jugs without leaking--still working that part out--I just wrap my hand around the hose to spout connection to seal it and refill our trailer fresh water tank as needed.
The extra capacity has nt caused any problem with holding tank capacity, but you will need to watch yours. I have found it easy to refill by setting the jug on the bedside of my truck parked a couple feet away, connect the clear hose and refill.
pira114
I'd call Airstream. Their Tech guys likely know if there's even room for a larger tank. Somehow, I doubt it. Especially in an enclosed space like you have.
Aside from bringing water containers to fill the tank, another option is water conservation. I bet most would be surprised at how much they can save.
Things like using the campground toilets whenever possible, washing dishes in a common campground water station if allowed, bringing jugs of water for drinking and cooking instead of using the tap (I like the 2.5 gallon jugs), not letting the water run when washing hands or brushing teeth (or not using your holding tank water for this at all).
A lot depends on how you camp. I basically only use my freshwater tank for flushing the toilet. Even then, it's only for late night/very early morning use.
I've boondocked in the forest for 7 days with a 29 gallon tank and came back with most of it.
BarneyS
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
harold1946
Harold and Linda
W-22 Workhorse 8.1L
Explorer Sport toad
Big_Love
I would not add that much additional weight to the TT. It is not that hard to add 5-10+ gallons of water at a time to your existing tank as necessary.
SoundGuy
Sam Spade wrote:
... essentially have an "endless" supply of fresh water. :B
SoundGuy wrote:
That's the approach I've used and now I find that answer intriguing......but some details are necessary to make it useful.
Details are in my gallery. Our current trailer has a 30 gal fresh water tank so when camping I carry four 7 gal Aquatainers in the back of my truck and can retrieve water anytime at my convenience. Normally I leave the house with the 'Tainers empty if we're headed to a conventional campground where fresh water is readily available but very early or very late in the season when the campground supplies may be turned off I fill them before leaving the house as well as filling the trailer's FW holding tank. Lotsa water. :B
2012 Silverado 1500 Crew Cab
Hunterred
Tank in the truck and a cheap transfer pump is a good idea, if that isn't what you are looking for, the you are likely looking at a second 40 gallon tank, you'll just have to find somewhere to put it. Our Jayco has 80 gallons (2x40) plus the water heater and it tows a lot heavier when filled with 700 lbs of water in it. Plus when full the trailer runs 97% of its GVWR so watch for that too. If you fund a spot underneath and fab up a bracket, some plumbing and you will have lots of water
Johno02
Fresh water tanks are usually sized depending on the combined capacity of the grey and black tanks. The idea is not to overfill either. Might want to keep that in mind.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
Sam_Spade
SoundGuy wrote:
That's the approach I've used and now essentially have an "endless" supply of fresh water. :B
I think that replacing the existing tank is NOT a practical thing to do in pretty much all makes and models but if you can find some storage space ON THE FLOOR that is difficult to use, that might be a good place to install a secondary tank and use a transfer pump to get it into the main tank.
In my unit, there is space under the fold down couch and under the bed that might be good locations.
Keep in mind that every extra gallon you have is an extra 8 pounds of dead weight you are hauling around. 50 gallons = 450 pounds.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
SoundGuy
JMO, but this is far more work than I'd ever want to put into a mod like this, especially considering that no matter how large the FW tank is it'll never be "enough" and chances are you'll have to have an efficient method of refilling it anyway. That's what I'd put my effort into - fresh water transfer i.e. a means to collect more fresh water as you need it without involving the trailer at all and a means to efficiently transfer that water into the trailer's FW holding tank, whatever size it may be. That's the approach I've used and now essentially have an "endless" supply of fresh water. :B
