kopy_kat
Oct 26, 2015Explorer
Larger tires on F350
I'm thinking about replacing my stock 275/70/18 tires with 285/75/18 Toyo AT II tires...has anyone else put this size on their Ford (2012 F350 6.7 diesel)??
Thanks, Larry
Thanks, Larry
45Ricochet wrote:up2nogood wrote:45Ricochet wrote:
I had one parked right next to me today, looked sweet but it was tall. Not sure it would match up with a fiver though. I would never chain the front end and I don't think Ram or Ford would recommend it either so clearance wouldn't be a problem for me.
Has a manufacturer ever recommended chaining the front . I have been chaining the front end on nearly every truck I've owned when hunting . The front is much more effective when chaining up and have chained all four many times . Never an issue other then turning sharp .
You would chain your front if you were in snow to nearly your front bumper :B
Yes I've been there and chain's ain't going to help that. That's why they make plows :B Actually I've only chained up the rear maybe 3 times in the last decade but that was for ice down the mountain road, not snow. At 300" per year I rarely even need a 4WD truck, about any AWD SUV can get the job done with the right tires..... No studs BTW :B
Location
Bedlam wrote:mudfuel07 wrote:
I just ordered a set of 305/70R18's for mine. I'm doing a leveling kit on it and wanted to fill the wheel well.
A F250 is level without the kit. It's for the F350 with 2" taller rear axle block. As soon as you put weight into the F250 you will be nose high and spending more money to lift the rear up more.
COnative wrote:
The reasons I went with the Toyo AT2's was for the fact that the highway tires that were on it were very sketchy in the Colorado Rockies in the winter. These new tires have an aggressive tread and should handle the mountain passes with ease. They are also getting good reviews. I also wanted to fill out the wheel well a bit, but not decrease clearance between 5er and truck bed significantly. The 295/70/18 also has a load and speed range of 129/126S.
