Brentyaks's avatar
Brentyaks
leaf spring under or over?
Hello, We have a KZ200, a small single axle 20ft trailer.
The problem we have is ground clearance. It looks like I can remove the leaf springs from under the axle and reinstall them over it. The wiring is plenty long enough and I will have to reconfigure the hitch.
Is it really as easy as that? My wife is understandably concerned with it having a top heavy issue if we raise it. Any thoughts on that?
Thank you all and I will help others,..... if I'm sure of the answers :)
Brent
  • I too did flip on mine and I like it. I'm tall so the step isn't a problem. I haven't noticed any difference in handling. But I must have done something wrong because I have increased tire wear. Fortunately I can tell the tires will age out before they wear out.
  • I had it done to one of my trailers I owned in the past. Didn't make any difference in handling and gave more ground clearance. As stated before go with a wet bolt kit and metal bushings.
  • An extra step will be a small price to pay to not have the camper's sewer pipe laying in my driveway after it hits. :) Thanks, I'm thinkin I'm gonna like this forum.
  • azrving wrote:
    Easy to do with the kit then weld the perch. While you are under there it's good to put in wet bolts and metal vs plastic bushings.
    Afterwards your stabilizers may be a little short and your first step may be a little high. Before you do it you can mock it up by pulling the TT up on to scrap lumber to see how that much lift will change things.
    x2, my son did order a new step. Plug N Play on his.
  • I did the axle relocation on my Layton because it was such a low rider and scraped my driveway backing in. My springs are now over slung and it was a huge improvement. Handling was no different than before the relocation. I reccomend it. I did rebuild the suspension while i had everything apart. Used wet bolts and now can grease everything annually.
    Good luck
  • Easy to do with the kit then weld the perch. While you are under there it's good to put in wet bolts and metal vs plastic bushings.
  • Hi Brent,
    That’s known as an axle flip, and is pretty common. Look up axle flip kits, they’re not expensive. Note that the axle cannot be turned “upside down” the orientation needs to remain the same.
    I’ve never done this myself, so I can’t comment on how this affects the handling and stability.
