LITEPHIL
Jul 09, 2022Explorer
Leaking fresh water tank
Has anyone replaced their under trailer frame mounted 40 gallon fresh water tank? I bought my 08 25 ft Salem used and first time I used it I noticed a drip near the drain plug but it stopped and didn't leak on my second trip. Now I filled it up and it's got a pretty good drip going, so I will have to fix it when I get back. But looking closely at the leak, it looks like it has been repaired and is leaking above the drain plug and not the plug its self. I suspect it had a low hanging drain valve that got ripped off and then was repaired and now there is just a plug there. I can tell the tank had been out before since there's a unpainted weld. Anyhow, has any one replaced their under belly tank ? and if so, where did you find one. It looks like a pretty straight forward job, with a small amount of welding on the cross support.
Thanks!
Thanks!
