Leaky trailer
niksagkram
Hi all. Well it's that time of year , finally (in Alberta) to de-winterize my trailer. I filled the fresh water tank, and turned on the water pump to pressurize the pump, and flush the system, and water started gushing out of the city water connection, and it won't stop until I turn off the pump. Any idea what might be happening here?
Thanks,
Mark
2003 Chev Silverado 1500 5.3
2003 Kustom Koach KT251
:B
8 REPLIES 8
niksagkram
Hi Thanks for all responses. I removed the old one and took it to my dealer, got a new one ($14.95) and replaced it in the trailer. Now works perfectly. ๐Ÿ™‚
In response to Daryll's question, I did release the pressure and drained any residual water, but, who knows, there could have been some left, or I broke it when I pressed it in.
Mark
:B
tatest
You can solve the problem temporarily by capping the city water inlet, but check valve should be fixed.
Tom Test
Itasca Spirit 29B
FLY_4_FUN
when you winterized did you pop off the conical metal debris screen and press the black button to release any residual water behind the city water input? if not the valve may have frozen/failed. Pop off that screen....depress the black valve a few times and try again. If water comes out again the valve has failed and is relatively inexpensive to replace.
Daryll
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
2015 Brookstone 315RL
2009 Colorado 29BHS (sold 2015)
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
niksagkram
Thanks for the speedy response folk.s I kinda figured that was the issue, but I thought I'd check with the experts first! ๐Ÿ™‚ This was my first winter with a travel trailer and I thought maybe I had missed a step while preparing to de-winterize.
:B
therink
Not a big deal. Yes, bad or stuck open spring loaded check valve ($10 part) Before writing off the check valve, try using an ice pick or small screw driver, (water pump off) gently push the check valve in and see if you can reseat the valve. If not, then replace it. If you need a temporary fix, thread a garden hose nozzle into the connector and the nozzle valve will temporarily stop water flow until you replace the check valve.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
GrandpaKip
Bad check valve.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Farm_Camp
Sounds like you have a check valve that's failed or gotten stuck open. When you run the pump you are forcing water back out that way. Or, maybe you have a valve in the wrong position (kinda doubtful).
TV: 2010 F250 XLT 4X4 SC SB 5.4L 3.73 - "The Blue Monster" (2013-2018) Traded at 100K
TV: 2017 F250 XLT 4X4 CC SB 6.7L PD 3.31 - "The Silver Streak"
TT: 2014 Starcraft Autumn Ridge 329BHU
Our Story...
Places we've camped
Dakota98
Check valve at the fill on the city water connection has malfunctioned.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
