May-27-2015 07:51 PM
Jun-09-2015 04:36 PM
May-30-2015 03:05 PM
May-30-2015 02:38 PM
May-30-2015 03:52 AM
bfast54 wrote:JPeyton wrote:
Waste of electricity to leave it on all the time. Plus sometimes they get a bit too hot and if the overheat censor fails it will start hissing out the relief valve. Plus wasting your element.
So......then do you turn your Water Heater off at your sticks snd Brick...?????..and just turn it on "when you use it"???????:h
May-30-2015 01:52 AM
reed cundiff wrote:
We have 81 gallons in freshwater tank and carry up to six x 6 gallon Jerrycans. With proper conservation, this will last us more than two weeks. Black water conservation will last three or more weeks and the limiting factor is grey water. If protocol permits tossing dishwater on ground and the use of outdoor shower, then we can last a month. Water points are usually available within an hour of dispersed camping sites so the 36 gallons in Jerrycans permits setting in for a lot longer time.
2006 Chevie 4 x 4 diesel (dualie)
2013 Open Range 337RLS
1.4 kW of solar (90 V from roof)
8.6 kW-hr of LFP (at 48 V nominal)
4.0 kW Magnum PSWI
TriStar MPPT-45
May-29-2015 07:56 PM
May-29-2015 07:37 PM
pappcam wrote:I boondock 100%.reed cundiff wrote:
We only turn heat with propane as required. It only takes 10 minutes or so to heat the water and can see no reason to leave it on overnight.
We do run the Dometic fridge on AC from battery/solar 24 hours a day on these great solar days at our older son's place in mountains of northern NM. Was not sure about using the solar/battery suite to heat the water but decided to try it and as Pianotuna noted, it does not take that many kW-hrs to do this. The power rate is fairly large, about 1.7 kW but it does not take more than 15 minutes to get to temperature.
Running both water heater and fridge, plus extensive use of microwave runs us 7 to 8 kW-hrs a day. If days are not sunny (it is supposed to be thunder storms tomorrow) than we change back to propane. Propane is not expensive but it means 1 1/2 hour round trip to Las Vegas, NM to fill tanks (we have 6 x 20# canisters) and photons are free.
Life with solar means changing energy management to suit the sun.
4.0 kW Magnum PSWI
TriStar MPPT-45
Boondocking is whole different animal. You have to manage your electricity quite diligently.
May-29-2015 07:36 PM
May-29-2015 07:27 PM
May-29-2015 07:20 PM
4.0 kW Magnum PSWI
TriStar MPPT-45
May-29-2015 05:06 PM
May-29-2015 03:25 PM
May-29-2015 02:40 PM
rockhillmanor wrote:Old-Biscuit wrote:rockhillmanor wrote:
Off.
Only takes one time for the thermostat to go out and it becomes a boiler bomb. Been there done that. Almost burned up the whole side of my RV.
Remember this is not your res hwh that is in the basement. It's right smack up against the walls. You couldn't even hold your hand on the side of my MH the wall was so hot.
And no those relief valves do not always work. And after having the mobile RV repair out to fix HWH......he said the RV relief valves almost always fail to open.
Now that is paranoia and RV Tech hogwash.
RV water heater uses the exact SAME T&P Relief Valve as residential water heaters.......buy them at Lowes/Home Depot/ACE etc.
T-stats......preset for higher water temp than residential BUT still use 2 t-stats just like residential water heaters do, normal temp and a high temp.
BOTH t-stats have to fail and T&P has to fail before water heater can begin to become a boiler bomb (I operated boilers for 30 yrs.)
Hogwash......
Well it was NOT hogwash with my HWH. I saw it fail first hand and felt how hot the walls got.
AND
http://forums.woodalls.com/index.cfm/fuseaction/thread/tid/28384129.cfm
30' 1990 Fleetwood, Pace Arrow:
I need to replace the pressure release valve on my water heater. T
Guess I am not the only one that needed a new RV pressure relief valve. :W
May-29-2015 02:35 PM
GaryWT wrote:pianotuna wrote:
Hi Gary,
No.
2.1 kwh x 12.5 cents = 26.25 X 30 days = $7.87
.7 x 12.25 = 8.76 cents X 30 days = $2.62
Now if you are running a generator to get that energy--the numbers become pretty high. The 2nd way--turning on first thing in the morning I can often use solar power for the energy, so it costs nothing.
If I am traveling I'll use the inverter and alternator to heat the water.GaryWT wrote:pianotuna wrote:
Hi,
On the electric setting the water heater will cycle every four hours and run for about 15 minutes. That represents 90 minute of run time and for my RV about 2.1 kwh. If starting from water 'at the ambient' it takes about 30 minutes to bring the water up to a temperature for a good hot shower in the morning. There is generally enough hot water left to get me to bed time. That represents only 0.7 kwh.
I tend to leave it on if someone else is paying, but will manually turn it off if I am paying.
So when you are paying the that is a 20 cents a day savings assuming your calculation of usage is correct.
Hi, sorry, I used 15 cents per kWh you used a lower number and two different ones but you example is only 17.49 cents a day, I estimated an extra 2.51 cents a day, sorry. Either way it is not that much.
