โMay-27-2015 07:51 PM
โMay-29-2015 02:33 PM
โMay-29-2015 02:14 PM
โMay-29-2015 12:37 PM
rockhillmanor wrote:pappcam wrote:
Why would anyone bother turning off the water heater, especially if you have electric hookups that you've paid for?? :h
Because propane does not come out of electrical hookups!!
Some of us have a propane only hot water heater. And those of us with MH's don't want to have to break camp to move the RV to get propane.And when I had my TT I hated having to unhook the propane tank and schelp it to get it filled. :W
โMay-29-2015 11:22 AM
pianotuna wrote:
Hi Gary,
No.
2.1 kwh x 12.5 cents = 26.25 X 30 days = $7.87
.7 x 12.25 = 8.76 cents X 30 days = $2.62
Now if you are running a generator to get that energy--the numbers become pretty high. The 2nd way--turning on first thing in the morning I can often use solar power for the energy, so it costs nothing.
If I am traveling I'll use the inverter and alternator to heat the water.GaryWT wrote:pianotuna wrote:
Hi,
On the electric setting the water heater will cycle every four hours and run for about 15 minutes. That represents 90 minute of run time and for my RV about 2.1 kwh. If starting from water 'at the ambient' it takes about 30 minutes to bring the water up to a temperature for a good hot shower in the morning. There is generally enough hot water left to get me to bed time. That represents only 0.7 kwh.
I tend to leave it on if someone else is paying, but will manually turn it off if I am paying.
So when you are paying the that is a 20 cents a day savings assuming your calculation of usage is correct.
โMay-29-2015 11:13 AM
rockhillmanor wrote:Old-Biscuit wrote:rockhillmanor wrote:
Off.
Only takes one time for the thermostat to go out and it becomes a boiler bomb. Been there done that. Almost burned up the whole side of my RV.
Remember this is not your res hwh that is in the basement. It's right smack up against the walls. You couldn't even hold your hand on the side of my MH the wall was so hot.
And no those relief valves do not always work. And after having the mobile RV repair out to fix HWH......he said the RV relief valves almost always fail to open.
Now that is paranoia and RV Tech hogwash.
RV water heater uses the exact SAME T&P Relief Valve as residential water heaters.......buy them at Lowes/Home Depot/ACE etc.
T-stats......preset for higher water temp than residential BUT still use 2 t-stats just like residential water heaters do, normal temp and a high temp.
BOTH t-stats have to fail and T&P has to fail before water heater can begin to become a boiler bomb (I operated boilers for 30 yrs.)
Hogwash......
Well it was NOT hogwash with my HWH. I saw it fail first hand and felt how hot the walls got.
AND
http://forums.woodalls.com/index.cfm/fuseaction/thread/tid/28384129.cfm
30' 1990 Fleetwood, Pace Arrow:
I need to replace the pressure release valve on my water heater. T
Guess I am not the only one that needed a new RV pressure relief valve. :W
โMay-29-2015 10:43 AM
Hi,
โMay-29-2015 10:03 AM
โMay-29-2015 09:54 AM
I have the best possible motivation, to keep DW happy. No logic about energy use or time spent waiting can trump that. She can be a light sleeper and can hear it cycle overnight if left on.
How does she hear the electric element turn on/off?
โMay-29-2015 08:49 AM
pianotuna wrote:
Hi,
โMay-29-2015 07:49 AM
Off.
Hogwash......
โMay-29-2015 07:34 AM
โMay-29-2015 07:23 AM
โMay-29-2015 01:45 AM
โMay-28-2015 08:57 PM
Lantley wrote:
The reality is there are no water heaters on all the time. The thermostats are turning the heaters on and off in an efficient manner to keep water hot.
The on and off control is automated. The heater turns itself on and off so we don't have to.
โMay-28-2015 06:05 PM
