- DaWheeExplorerHowdy Again,
We are looking at a Lippert 6 point hydraulic leveling system. We are heading that direction for vacation, so it makes more sense to have the folks whose product it is, install it. They're engineers ordered the frame drawings from our fifth wheel manufacturer, and see no issues. They have communicated with them as well. At least with a Lippert system we will be able to have it serviced almost anywhere in the event of an issue. Thanks folks.
Dave - love2rvcampExplorerI was at the RV show last weekend and looking at trailers and the one we liked there was a couple there just looking that said they were having the Level Up system installed on their travel trailer. They were from Florida so not sure who was doing the install but they said the out the door price for installation and hardware was about $4,000.
- HuntindogExplorer
Ralph Cramden wrote:
In theory, a 6 jack system with the two middle jacks located close to the axles shouldn't hurt the frame. But there are some pretty weak frames out there. I have even seem THs with large sections of the frame webbing cut out to save weight. A frame such as that needs to be babied.Huntindog wrote:
bobndot wrote:
I am fairly certain that this is a hydraulic system.. Only one motor for the entire system. and the ones I have read about are 6 jack systems. A four jack system would be bad news for just about any TT frame.
From experience with electric rv jacks in general, motors can burn out and the tubes can bind, make sure you know how to repair them.
There location is susceptible to road dirt. When dealing with digital electronics it pays to use quality command modules and quality motors because you have 4 of them.
And it could be bad news no matter 4 or 6 jack if the trailer was not designed to accommodate it. Its not as easy as just taking off stabilizer jacks and adding leveling jacks. If they tell you not to "jack up/level" a trailer with the stabilizer jacks adding automatically operated jacks that raise the entire rig off the ground may not be the best idea?
One would think a company like Lippert who makes frames and the jacks, has the engineering who could tell you what would work and add additional reinforcement if required. Then again seeing that they produce standard tank support pieces that have been known to deflect and allow tanks to drop right out of a trailer, I'm not so sure LOL. - bobndotExplorer IIThank u Huntindog and Ralph C for that info.
- drsteveExplorer
BurbMan wrote:
This is the travel trailer forum
True. But sometimes stuff happens. - ependydadExplorer
Second Chance wrote:
ScottG wrote:
Isn't there anybody else that makes a system like that?
I only ask because Lippert is so synonymous with poor quality rv parts.
Bigfoot has the best reputation among full-timers in the Escapees club:
Bigfoot leveling systems
Rob
Agreed, if I was adding a leveling system after the fact- it would be a Bigfoot. - BurbManExplorer IIThis is the travel trailer forum
- drsteveExplorerAre we talking about a pull behind or a MH?
- shfd739ExplorerSeems pretty expensive for something that most travel trailers frames may not be capable of handling. Ive read some owner reviews that said you still need to level under the axles and this is more of an auto stabilizer.
http://www.campingworld.com/ground-control-tt-leveling-system - Second_ChanceExplorer II
Rob
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
