- ata3001ExplorerThe hitch you bought is just fine for your trailer/truck combo. It just needs to be properly set up. There are enough others on here telling you how to do it without me adding my own $.02
- hohenwald48Explorer
SoundGuy wrote:
lukenick wrote:
Either the coupler needs to be mounted on top or I will need a new hitch system.
There's little sense in modifying the trailer when the simple solution is to switch to a weight distribution system which by it's design offers maximum ground clearance. Here's a pic of an Equal-i-Zer Weight Distribution Hitch mounted on our previous KZ Spree. As you can see there are no chains and the spring bars are straight unlike the "hockey stick" spring bars your current round bar chain WD system uses. There's also no need for a separate friction sway bar as sway control is a function of the design of the Equal-i-zer.
Now, take your hitch and drop the ball mount all the way down to the bottom hole and you'll see almost all of your ground clearance disappear.
Jayco intentionally designed these trailer to sit as low to the ground as possible. I have no idea why they would do that but ground clearance problems with them is not unusual. Apparently Jayco even knew it could be a problem because a 2" lift kit was available as an option. - hohenwald48ExplorerI agree with Tom. No hitch will resolve the need for the dropped shank. Getting everything (bars etc.) higher than the shank just means the shank is going to be the low spot and drag the pavement. Potential for some serious damage when and if that happens.
If the problem is just the ends of the bars dragging, that might be fixable by simply adjusting the head tilt. First step is to get it looked at by someone who knows what they're looking at. - TomG2ExplorerHow are any of the hitches going to change the necessity for the 11 inch drop bar? The Recurve might even need more. I would lots rather skid the bottoms of the WD bars than have that 11 inch solid steel bar grab hold of a concrete ramp. The coupler needs to come up. Then you guys can sell her all the hitches she can afford.
- Ron_GratzExplorer
lukenick wrote:
Seems to me the Recurve would be the ideal hitch for your situation.
---I do believe they sell the Eaz lift Recurve R3 and R6. Those would also work out great for my situation because the round bars go on top. Let's see if they will swap it for me.---
Ron - lukenickExplorer
chipperone1 wrote:
If you go with an Equalizer as was suggested -which is a good option - because the coupler is under slung the new spring bars will be lower for you than was shown in the pic by a few inches so you will not gain the full benefit of using that style of WDH.
If you keep the existing WDH get yourself a longer bar/pipe - like three feet long- to use to "snap up" the chain brackets. How long is the one you use?
The one I have is prob 12". - TomG2ExplorerSeveral have suggested that the easiest solution is to buy another hitch. Easy, as in, easy to spend her money. How about if she still needs the extended drop bar? That may be what is scraping the pavement, not the hitch bars.
- SoundGuyExplorer
lukenick wrote:
I lift the truck so high as it is just to get the second link hooked up there is no way I would be able to get any more chain links connected. I am 110 lb female hitching up, and the tension is just too much for me.
Another WD system you might be interested in is the Andersen No Sway Hitch because it's so light, about 50 lbs if I recall correctly, and because it's tension chains sit well up near the trailer A frame. - chipperone1ExplorerIf you go with an Equalizer as was suggested -which is a good option - because the coupler is under slung the new spring bars will be lower for you than was shown in the pic by a few inches so you will not gain the full benefit of using that style of WDH.
If you keep the existing WDH get yourself a longer bar/pipe - like three feet long- to use to "snap up" the chain brackets. How long is the one you use? - dodge_guyExplorer IIThe easiest and cheapest for all involved would be to swap out to a trunnion hitch. You said you got the hitch from the dealer? Have them swap it out and then see how the ground clearance issue is.
Never mind, it looks like you brought them a hitch to install!
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 21, 2025
