Lemonhead78
Apr 08, 2019Explorer
mobeewan wrote:
If the cap is a Flair-it cap and looks like the one in the link, there is no gasket. Those caps are used to cap Flair-it fitting where the PEX tubing has been removed. They seat against the Barb the PEX normally slips over before tightening the nut used to hold the PEX to the fitting. They will hold pressure up to the rating of the fitting, valve or PEX tubing without a gasket.
I have a couple I keep on hand in case I have a plumbing problem and have to disconnect a piece of PEX until I would have time to make a repair. I used one once to temporarily cap a tee I added where I was adding a new PEX line where I was installing a captive air tank. I still needed to use the trailers fresh water system before I had time to finish the tank install.
So what am I suppose to do. I checked hardware stores and the rv parts department where I bought trailer it and no one can help. I’m getting depressed over this. I called forest river and that was a joke.
