biggjb's avatar
biggjb
Magnatex 6300 Converter issue
I bought an old 1999 Fleetwood Elkhorn and it came with a Magatex 6300 Q-series converter. I have no problem with my 12v or 120v systems, however, the converter does not charge my batteries when plugged into shore power. I have made some research and found a Progressive Dynamic 4635 which can replace the lower section of my Magatex converter. My camper is rated at 35 amps, however, I was wondering what the problem would be if I upgraded to a 45 amp converter.
  • Just be careful to double check everything before powering up. Even if you think you for sure got it right.
  • Thanks everyone for help and advice. I will upgrade the Magatex with the 45 amp PD...wish me luck as I am not very good with the electrical system.
  • The old 1999 convertor you have I would be changing out even if still working. They been known to almost always shorten battery life. Make sure you get a three stage charger that knows how to go to float... around 13.5 volts after bulk and absorbtion charge phases.
  • Any of progessive dyanamics 9200 series converters will work and they have built in charge wizards so pendants are purely optional. I think you can pick up 45 amp for about $170 on Amazon.
    Before you buy a new converter - have your batteries tested/checked (free), make sure you battery ground is OK, and check for a defective auto-reset circuit breaker near your battery. Defective batteries won't maintain charge and bad auto reset breaker will prevent converter from charging battery.
    Just verify the battery charging loop is larger than #10 wire.
    Either way the PD will charge like a rocket compared to the 6300.
