owenssailor
Jul 29, 2019Explorer
Your 2017 should tow that trailer fine. Ours does. As for braking - remember that the trailer has brakes. Look at a transport. The tractor does not have the braking power to stop the whole load.
Going up long steep grades your engine will rev. That is no problem. It won't hurt anything. Those small blocks are used in lots of power boats where working rpm is 4000 plus.
If you have P-metric tires on the truck air them to max PSI from the sidewall.
Be sure to get a good hitch with built in sway control and set it up correctly/
Have fun
Have fun
44,029 PostsLatest Activity: Jan 20, 2025
