beau9
May 13, 2014Explorer
Metal roof coating
Hi all, new to forum. Picked up a 1968 Norris travel trailer with metal roof and my first order of business is to stop the roof leaks. Did some research on this forum and elsewhere but found no specific answers. So I came up with this plan:
1. Replace sagging wood ceiling joists to restore crown in portion of roof
2. Clean, scrape, sand off existing coating that is peeling
3. Eternabond webseal seams in metal roof that run across width of trailer
4. Install 2 new roof vents, frig vent and bath vent with new butyl tape kits
5. Webseal flanges of new vents
6. Apply Liquid Roof EPDM coating to entire roof
Guess I should look at edges too and replace butyl tape as needed under trim. Or can I use an epdm compatible caulk to seal edge trim to roof?
Am I creating a problem for myself by applying rubber roof over flanges and up to edge trim? Should I install vents/edges after rubber roof is down and rely on butyl tape?
Any critiques, comments and/or recommendations are greatly appreciated.
