Cliff_and_Miche
Aug 04, 2022Explorer
Soondockin, I have a new Ram 5500with flatbed and as of yesterday, a Northern-Lite 10-2LE DB. The truck, without the camper, gave me shaken baby syndrome after just a few miles and if I hit an expansion joint, a traumatic brain injury to boot. Even with the camper, it is still a pretty rough ride. We will prolly go with the Liquid Spring system as they reportedly make the ride between a 1500 and a 2500 truck. Another advantage is when I am parked in my driveway with a 4 degree down slope, I can lift the front 4” and drop the rear 4” to level it out to get the fridge to work. Note that the Liquid Spring manufacturer says you have to remove the 22 gallon fuel tank to install the power unit, leaving just the 50 gallon tank. A friend of mine found an alternative place to mount the power unit so keep that in mind. I won’t do a 3500 series truck despite all the enthusiasts’ comments. I owned dump trucks and a truck built for 80,000 pounds and a truck built for 58,000 pounds, when both loaded to 60,000 pounds, the heavier built truck handles it much more comfortably where the lighter built truck handles it adequately. Which one do you think is more pleasant t to drive?
44,026 PostsLatest Activity: Feb 24, 2025
