โApr-28-2013 03:03 PM
โAug-23-2013 02:29 PM
โAug-22-2013 02:18 PM
markowwes wrote:
Go the 550 routeโฆ..it may cost a little more, you will be more than happy with the outcome. We purchased ours out of Helena Montana, will never look back.
No worries about weights now!
โAug-21-2013 11:01 AM
โAug-21-2013 07:25 AM
โAug-20-2013 07:51 PM
mkirsch wrote:
An F350 dually will carry a dang big camper all by itself with no need for gadgets, doodads, widgets, wingdings, gadspackers, or mucktinkles.
โAug-20-2013 06:26 PM
mkirsch wrote:Just Jeff wrote:mkirsch wrote:
Why fixated on the brakes? I've never not once seen anyone mention "beefing up" the brakes for a TC.
Only "beef up" the suspension if you need it. An F350 dually will carry a dang big camper all by itself with no need for gadgets, doodads, widgets, wingdings, gadspackers, or mucktinkles.
Really? Look around - it's out there. Carrying heavy loads is harder on the brakes, so there's a reason heavier duty trucks come with heavier brakes. Not saying they're absolutely required, but it gives more control and the brakes don't wear out as fast b/c they're not being used near their max capacity.
There's a difference between a truck having heavier (i.e. "beefed up") brakes vs. the lighter-duty model, and actually swapping out brake parts on the truck.
I've been on this forum since 2004 and I have yet to read of anyone having taken the factory brakes off their F250, F350, or any other HD pickup and replacing them with "Brembo" or other performance brake parts.
Suspension, yeah. I don't agree with what a lot of people do because they go out and buy the truck then throw $$$thousands$$$ more at their BRAND NEW truck to upgrade it to handle the camper. But yeah, I'm well aware of the suspension mods.
Never seen anyone even consider BRAKES, however. Stock brakes on the F250 are apparently fine even if you've got a 4000lb camper and 19.5" wheels.
Really, if you think about it, the brakes should be at least adequate. The HD brakes on these trucks are designed to stop the truck loaded to GVWR, plus presumably another 3000lbs of trailer (3000lb is the limit in many states where trailer brakes become a requirement).
โMay-07-2013 04:42 PM
wintersun wrote:
Comment about the frame is the stiffness and strength of the frame and not its "width". The fully boxed frame on the current GM 1-ton trucks are a great deal stiffer and reduce flexing with SRW and DRW configurations a great deal compared to the Ford trucks in this class. The new 2013 1-ton Ram trucks have a new beefier frame with additional cross members to handle the added CGWR of these trucks (frame upgrades not provided with the 3/4 ton Ram pickups). I have had trucks with cracked frames and broken leaf shackles (tore away from the frame). Not easy to repair a frame and it is not going to be "good as new" afterwards.
In your situation I would look at that as an opportunity to add a storage box in that space or an auxilary fuel tank. It would put the COG of the bed load further forward. COG is usually measured from the rear of the camper and rear of the truck box so that it by design the camper's COG is directly over the rear axle. I have been in vehicles where the weight on the rear axle tended to reduce the weight on the front wheels and it was far from safe and no fun either.
A CAT scale weighing of the truck alone and again with the camper in the bed will tell you whether or not there is any cause for concern. Until you do it is anybody's guess. I don't like to guess about such things.
โMay-06-2013 02:07 PM
โMay-05-2013 07:04 PM
โMay-05-2013 06:27 PM
wintersun wrote:
With trucks I have always found it cheaper and usually much cheaper to get any heavy duty upgrades from the factory as compared to waiting and doing it later with aftermarket parts and shop labor. And with a truck I have had enough experience with frame and frame attachments over the years to want to be sure the frame will handle the load both on and off road. It is why for our heavy duty truck I went with the GM fully boxed frame which in the 2500/3500 class trucks is the best available.
DRW adds leveraged stress to the frame and increases torsional twisting a great deal more than SRW axles. Going to a DRW I would be looking at a F-450 or better and check that the frame is truly beefier. I doubt that the F-450 is any better than the F-350 in terms of the frame and subcomponents in general and I would go the extra step up to the F-550 platform.
With the F-550 one opens up another can of worms in terms of whether to get a box conversion and have a standard camper setup with its lower centery of gravity or to have a flatbed setup which add more weight and be tippier but provide more storage options.
Going to a F-550 and a 11' camper I would be also checking out Class A and B+ motorhomes as well.
โMay-04-2013 04:10 PM
โMay-04-2013 03:59 PM
โMay-03-2013 10:16 AM
KD4UPL wrote:
I never said the truck manufacturers made the law, only that they hopefully are aware of it. Just because your manual says that doesn't mean they all do. On page 4-88 of my Chevy manual it states: "If your trailer weighs more than 2,000 pounds loaded, then it needs it's own brakes - and they must be adequate"
This says to me that the brakes on the truck must be adequate for up to an additional 2,000 pounds over the truck's GVWR.
โMay-03-2013 09:17 AM
โMay-03-2013 08:59 AM
