swimmer_spe's avatar
swimmer_spe
Modifying the plumbing.
I have a 75 Terry TT.
Right now, the drains drain to the holding tank and then out. I am not using the holding tank now. I do not want to use it ever.
I plan to remove the bathroom fixtures. I want to run the kitchen sink into the ground.
So, to do this: Can I just cut the pipe going to the tank and direct it into the ground? The other drains have vents. Can I just cap the pipes at the roof, or must I remove it and repair the roof?
The trailer will not be moved anywhere anytime soon and there is no issue with grey water going directly to the ground.
