adamis's avatar
adamis
Nomad II
Dec 19, 2020
Moving LiFePo4, Rewire or run Long Extensions?
On my Bigfoot Camper my battery compartment is on the outside compartment of the camper. The door is just a lightweight metal door with vents in it (no insulation). There are no heater vents to the compartment either. On a recent camping trip in early Fall we were up near Lake Tahoe at high elevation. The temps at night got into the low 30s / high 20s. We had to run the heat all night to keep our twin babies warm (can't smother then in blankets) and my 100ah Battle Born LiFePo4 couldn't make it through the night running the furnace (another upgrade project). We had to run the truck in the early morning to start charging the battery and I noticed that it was charging really slowly at about 3 amps (I have a 20 amp DC to DC Renogy charger installed). It took me a while to realize the slow charging was because the BMS was likely limiting the current while the battery was so cold. Later it charged around 15 amps. Although we don't camp in the off season often, it is something I would like to be prepared for. Moving the battery to keep the temperature maintained better seems like a worthwhile endeavor.
I'm considering moving the battery inside the camper, under the dinette seat right next to the onboard charger / inverter. The conundrum I face is, I currently have appropriately sized wire for a 2000w inverter, my 20 amp charge controller, 200w (soon to be 400w) of solar plus my genset all wired to the current battery compartment. I can rerun all of these to the new compartment at extensive time and effort. It would shorten the run for the solar but lengthen the run for the inverter / genset.
The alternative is to just run some heavy gauge wire to bridge between the old compartment and the new compartment. Less work overall but running thicker cable (thing 4awg or suggestions...) can be more difficult in the tight spaces. I will do the work if it really is necessary but I'm thinking about taking the easy route on this one.
Thoughts?
