johnnylawless's avatar
Aug 19, 2014
My Electric System - Am I going to die?
Travel Trailer: 1983 Man-O-War 15'
Where the 120V AC 30amp comes inside (driver side):
Converter Close Up (passenger side, front corner):
Input Current - 3.75 Amps AC
Input Voltage - 120 Volts AC
Output Current - 25 Amps DC
Output Voltage - 12.6 Volts DC
Converter Overhead (passenger side, front corner):
Fuses Closeup (driver side, front corner):
Fuses Overhead (driver side, front corner):
QUESTION #1: Is there an immediate concern?
So that fuse box looks pretty corroded. Is that a bad thing? What about the stripped paneling to the top right and left of the fuse box, is that from excessive heat?
QUESTION #2: What is the loose bundle coming out of the right side
of the fuse box?
QUESTION #3: Flipped fuse? No fuse? Everything I've tested seems to work on shore power.
I have no battery yet. What is the point of this fusebox, is it to prevent over draw from 12V DC items (currently only lights I think)?
QUESTION #4: What is the loose wire (red/yellow) coming out of the converter? Is that for the battery connection?
QUESTION #5: Any idea if a battery will power my AC Outlets or are they shore power only?
Miscellaneous Questions:
* Any idea what amp fuses those are?
* How do I add a battery?
* Does this electrical look original or custom?
* Am I going to die?
Thank you in advance for your help!
