bbaker2001's avatar
bbaker2001
my loaded weights,??
heading to Oregon.
Ram 3500 SRW
diesel
GVAW front 6000 rear 7000 truck GVWR 12,300
after loading everything up, got it weighed
Front 5450
Rear 6650
Total 12,100
I know I am under, but it is so close. is it really ok
  • You're good! Enjoy. Can't do much better then you already have for a tow rig even if you wanted to.
    And best of luck with the treatments. Keep yer head up!
  • Just for comparison purposes, I hauled a 37' 14,500 GVWR 5th wheel with a Chevy 2500 diesel. The Chevy hauled it really well. Your Ram will haul your lighter trailer with ease.
  • just spent 2 weeks Bullard's beach, am in Klamath now, and have to go back to California for more chemo, then back to coast
    thanks all.
    I do not know what everyone carries in back of truck, but seems we should all be close if hauling a 5er. and mine is only 30'. cardinal GVWR is 12,300
    of course it is a 2001. probably heavier back then
  • KD4UPL wrote:
    Under is great. Equal-to is fine. Over isn't always that bad depending on a lot of other things.
    Your in great shape.
    X2!
  • Under is great. Equal-to is fine. Over isn't always that bad depending on a lot of other things.
  • you have the fudge factor
    and the legal gap factor.
    and the what/if factor..
    you are good to GO........ Have a Safe and Fun trip.
    remember to check the air and tire temperature every chance you get.
  • No worries. That truck can pull way more than that. Where are you heading to?
