- recyclerExplorerWell I know this is a terribly old thread by I was browsing through it and saw mention of the Cummins being in the truck.
And here's a rough idea of what it may look like. - recyclerExplorermoderator please close this thread..
- recyclerExplorerwell i got the doublers off and primed and painted the frame...
- recyclerExplorer
Reality Check wrote:
Butch50 wrote:
You are right on my truck.
My truck was done by Manning which across the street from Ford factory. It does have a 4" piece that fills the gap between the front of the bed and the back of the cab. The chassis cabs wheel base is 4" longer than a standard F350 so the bed has to be moved back by 4" or the frame needs to be shortned by that amount. It was a formed piece that looked like it fit right there. It was hard to really notice it at just a glance.
Yep, they fit.
I couldn't get rid of that bed fast enough (the one on my 550 when I got it). Yes, it had the filler piece too. Why anyone would want a pick up bed for anything other than getting grocery's is beyond me.
because some of us have to deal with states that have rules that classify anything other than a pick up bed on your truck as commercial and can require you to go through weight stations and have commercial plates etc.. - Reality_CheckNomad II
Yep, they fit.
I couldn't get rid of that bed fast enough (the one on my 550 when I got it). Yes, it had the filler piece too. Why anyone would want a pick up bed for anything other than getting grocery's is beyond me. - Butch50ExplorerYou are right on my truck.
My truck was done by Manning which across the street from Ford factory. It does have a 4" piece that fills the gap between the front of the bed and the back of the cab. The chassis cabs wheel base is 4" longer than a standard F350 so the bed has to be moved back by 4" or the frame needs to be shortned by that amount. It was a formed piece that looked like it fit right there. It was hard to really notice it at just a glance. - ticki2Explorer
Butch50 wrote:
mike mck wrote:
Stefonius wrote:
A pickup bed won't fit on an F450/F550. The frame rails are narrower, taller and flatter than on the smaller trucks.
Michigan isn't too far from Indiana, and there's a shop called Utility Body Werks in Elkhart that does incredible work with these trucks. They did the bed on my 450 and I can't stop grinning when I look at it in the driveway. They might be worth checking out.
http://www.utilitybodywerks.com/index.html
Pick up bed fits nicely on my 1999 F550. You are correct rear frame on the F350 is 37" while the F550 is 34". On my truck Frame was shortened. In Az my plates are commercial based on vehicle weight but ins and tag cost are not at the commercial rate.
Where are the pics of this project? You all know the rules. No pics it didn't happen.
I know this is an old thread but I would like to add a couple of pictures of my truck I had built for me but no longer have.
That's funny that a pickup bed won't fit on a F450/550 as the 2006 F550 I had built for me had a pickup bed on it also.
Butch it looks like the bed on your f550 has an extention to make it fit . MikeMCK said his frame was shortened . Usually a chassis/cab has a narrower width rear frame and a longer wheel base . I don't think a standard pickup bed will fit a f550 without some modification . - recyclerExplorerwell you know how some projects won't die...well this one didn't either thank you mother nature..it however is going a different route as a hauler..with a built in camper..
- Butch50Explorer
That's funny that a pickup bed won't fit on a F450/550 as the 2006 F550 I had built for me had a pickup bed on it also. - mike_mckExplorer
About Travel Trailer Group
44,027 PostsLatest Activity: Mar 06, 2025
