wsdepa
Oct 16, 2014Explorer
Need Help Replacing Servie Panel
I have a Lance 2005 Max 981 camper and after eight years and 100,000 miles of heavy use, I have decided to rebuild the service bay. The main problem is that the panel is cracking and falling apart. I was delighted to find that Lance still had the part in stock and so I order it and it arrived a few days ago. Today I tackled the project and everything went very easily, it's just removing screws and bolt and drilling out some rivets, until I tried to remove the pull cables that operated the black and grey valves. It seems that the fitting that clamps them to the panel is swaged onto the end of the cable housing and maybe it might need to be disconnected from the valve end. I sure hope not since this would involve removing the belly panels and who know what else. Here are some pics to show you what I mean. I hope someone out there has done this and tell me the secret trick.
![](https://lh6.googleusercontent.com/jICufkMaPjRcvRIKaVdJE-mvYRagKiwiGvOIGMdOXRA=w276-h207-p-no)
![](https://lh4.googleusercontent.com/LjnylS4w6trWYed_GLTx6PHZZhZomPi9_c7FRe4Teuw=w145-h192-p-no)
