mobilefleet's avatar
mobilefleet
need help with wiring on KIB monitor panel
I bought a vandalized unit(2018 keystone cougar) and it has a KIB model 25 monitor panel with 3 lighted switches (water pump, gas and electric water heater switches) and also has 5 buttons to press for battery/fresh/black/grey 1/grey 2
They tore the wires off the back of the panel but the spade connectors are still there, just not sure what color goes to which terminal, and there are 9 terminals on the back of this model. Any ideas or help? Can't find a diagram online with color codes
    Never assume anything about wire color. Even IF a mfg intends to use certain colors they will not stop production because a certain color is not available. Nor is there any requirement for wire colors.
  • Maybe this will help some.
    https://pdxrvwholesale.com/products/kib-electronics-monitor-panel-model-m25-2hwl-repair-installation-kits
    Otherwise contact KIB Service & Warranty @ 574-262-0518 (merged with American Technology Components support at 574-322-5505)
