westend
Aug 18, 2014Explorer
NHIrish wrote:westend wrote:
Two things stand out to me from the pictures: First, that whole seam is holding water on the roof like a dam. Second, the caulking material is failing.
I would remove all of it and re caulk or use Eternabond tape, whatever is the choice of the OP. I've found that Eternabond tape is superior to any sealant I've used.
I would agree....am in the process of doing the same myself. I am using a metal putty knife with the corners ground off and it is working well. If you were to buy the 6" wide you probably wouldn't have to remove the old...also would use their spray cleaner.
Good advice about the cleaning, Eternabond needs a surface that is scrupulously cleaned. Of the few Eternabond failures that have been posted here, all were the results of less-than-stellar surface prep.
The only problem I see with covering a big gob of failing sealant is that the original sealant may continue to degrade and a loose void may develop underneath ANYTHING applied over it.
I see a lot of members here apply Dicor lap sealant over more gobs of sealant and I presume they're successful. It kind of goes against my construction experience outlook (applying caulk over failing caulk isn't acceptable). YMMV
44,025 PostsLatest Activity: Feb 26, 2025
